Lenovo IdeaPad Y500 Fan Replacement
Introduction
Go to step 1Use this guide to replace the fan on your Lenovo IdeaPad Y500. The heat sink assembly, the copper-colored extensions from the fan, is also attached to the fan of your device.
Slide the lock on the right side until you hear a click. Once you hear a click , you should see the color red.
Remove a total of 8 screws.
Red circles are m2.5 x 10 mm flathead screws.
Orange circles m2 x 3mm flathead screws.
Yellow circle is m2.5 x 4mm flathead screw.
Unlock the battery latch by pulling it up.
It should reveal red underneath when it's unlocked.
Peel up the black tab and remove the tape completely.
Remove the cable revealed underneath while pulling up the tape.
