Lenovo IdeaPad Y500 Keyboard Replacement
Isabella Morvel
Isabella Morvel and 5 other contributors
Last updated on January 5, 2021
15 minutes
Moderate
Introduction
Go to step 1
Utilize this guide to remove or replace a keyboard that is no longer functioning correctly from a Lenovo IdeaPad Y500. Creating a backup for your hard drive is recommended in case of damage caused during keyboard removal.  Unplug the computer before any further steps are completed to avoid damaging components of the device.
After removing the old keyboard, repeat all steps in reverse order(starting with the final step and finishing with step 1) to reassemble your device. Consult your local regulations concerning the disposal of electronic waste materials.
Tools
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Lenovo IdeaPad Y500 Keyboard Replacement, Battery: step 1, image 1 of 3 Lenovo IdeaPad Y500 Keyboard Replacement, Battery: step 1, image 2 of 3 Lenovo IdeaPad Y500 Keyboard Replacement, Battery: step 1, image 3 of 3
    • Slide the lock on the right side until you hear a click. Once you hear a click , you should see the color red.
  2. Lenovo IdeaPad Y500 Keyboard Replacement: step 2, image 1 of 1
    • Unlike the first lock, this lock is spring loaded and must be held in place when used.
    • Slide the lock to the left (in the direction of the arrow below the lock) and hold in place.
  3. Lenovo IdeaPad Y500 Keyboard Replacement: step 3, image 1 of 1
    • Gently pull battery away from the computer while holding open the lock.
  4. Lenovo IdeaPad Y500 Keyboard Replacement, Keyboard: step 4, image 1 of 3 Lenovo IdeaPad Y500 Keyboard Replacement, Keyboard: step 4, image 2 of 3 Lenovo IdeaPad Y500 Keyboard Replacement, Keyboard: step 4, image 3 of 3
    • Unlock the battery latch by pulling it up.
    • It should reveal red underneath when it's unlocked.
  5. Lenovo IdeaPad Y500 Keyboard Replacement: step 5, image 1 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 5, image 2 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 5, image 3 of 3
    • Push the latch down and then hold in position.
    • Pull the optical drive out.
  6. Lenovo IdeaPad Y500 Keyboard Replacement: step 6, image 1 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 6, image 2 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 6, image 3 of 3
    • Remove nine screws with a Phillips #1 screwdriver.
  7. Lenovo IdeaPad Y500 Keyboard Replacement: step 7, image 1 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 7, image 2 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 7, image 3 of 3
    • Pull up on the loosened cover to remove.
    • Remove two screws with a Phillips #1 screwdriver.
  8. Lenovo IdeaPad Y500 Keyboard Replacement: step 8, image 1 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 8, image 2 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 8, image 3 of 3
    • Pull the tab straight to the left until part releases.
    • Lift up the part to remove completely.
  9. Lenovo IdeaPad Y500 Keyboard Replacement: step 9, image 1 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 9, image 2 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 9, image 3 of 3
    • To release the DIMM, pull the tabs on either side away from each other simultaneously.
    • The DIMM will pop out on its own.
  10. Lenovo IdeaPad Y500 Keyboard Replacement: step 10, image 1 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 10, image 2 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 10, image 3 of 3
    • To disconnect the Wi-Fi cables, use a spudger to gently push up under them.
    • Wi-Fi cables are delicate.
  11. Lenovo IdeaPad Y500 Keyboard Replacement: step 11, image 1 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 11, image 2 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 11, image 3 of 3
    • Using a Phillips #1 screwdriver, remove the two screws.
    • Once screws are out, the card will just pop out.
  12. Lenovo IdeaPad Y500 Keyboard Replacement: step 12, image 1 of 1
    • Remove three screws using a Phillips #1 screwdriver.
  13. Lenovo IdeaPad Y500 Keyboard Replacement: step 13, image 1 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 13, image 2 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 13, image 3 of 3
    • With the laptop upside down, open slightly.
    • To remove the keyboard, push the back of the keyboard forward with your thumb while pulling away from the laptop on the other side.
    • You will not be able to pull the keyboard completely away. The cables are still connected to the laptop.
  14. Lenovo IdeaPad Y500 Keyboard Replacement: step 14, image 1 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 14, image 2 of 3 Lenovo IdeaPad Y500 Keyboard Replacement: step 14, image 3 of 3
    • To release the cables, use the spudger to push both ends on the side of the cable.
    • Gently pull the cables up to disconnect.
  15. Lenovo IdeaPad Y500 Keyboard Replacement: step 15, image 1 of 2 Lenovo IdeaPad Y500 Keyboard Replacement: step 15, image 2 of 2
    • Pull the keyboard up and away from the laptop to remove it.
3 other people completed this guide.
Isabella Morvel
250 Reputation
1 Guide authored
One Comment
Not sure if removing all components was really necessary just to replace the keyboard but I still did it and succeeded in replacing the keyboard. Thank you for great and detailed instructions.
Grzegorz Krugły - Reply
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 15
All Time: 2,067
