Lenovo IdeaPad Y500 Touchpad  Replacement
Tatum Hennige
Tatum Hennige and one other contributor
Last updated on June 17, 2019
5 minutes
Moderate
Better Introduction
Introduction
Go to step 1
This guide will help you take off your front casing in order to access your touchpad.
Tools
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  1. Lenovo IdeaPad Y500 Touchpad  Replacement, Battery: step 1, image 1 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement, Battery: step 1, image 2 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement, Battery: step 1, image 3 of 3
    • Slide the lock on the right side until you hear a click. Once you hear a click , you should see the color red.
  2. Lenovo IdeaPad Y500 Touchpad  Replacement: step 2, image 1 of 1
    • Unlike the first lock, this lock is spring loaded and must be held in place when used.
    • Slide the lock to the left (in the direction of the arrow below the lock) and hold in place.
  3. Lenovo IdeaPad Y500 Touchpad  Replacement: step 3, image 1 of 1
    • Gently pull battery away from the computer while holding open the lock.
  4. Lenovo IdeaPad Y500 Touchpad  Replacement, Keyboard: step 4, image 1 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement, Keyboard: step 4, image 2 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement, Keyboard: step 4, image 3 of 3
    • Unlock the battery latch by pulling it up.
    • It should reveal red underneath when it's unlocked.
  5. Lenovo IdeaPad Y500 Touchpad  Replacement: step 5, image 1 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 5, image 2 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 5, image 3 of 3
    • Push the latch down and then hold in position.
    • Pull the optical drive out.
  6. Lenovo IdeaPad Y500 Touchpad  Replacement: step 6, image 1 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 6, image 2 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 6, image 3 of 3
    • Remove nine screws with a Phillips #1 screwdriver.
  7. Lenovo IdeaPad Y500 Touchpad  Replacement: step 7, image 1 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 7, image 2 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 7, image 3 of 3
    • Pull up on the loosened cover to remove.
    • Remove two screws with a Phillips #1 screwdriver.
  8. Lenovo IdeaPad Y500 Touchpad  Replacement: step 8, image 1 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 8, image 2 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 8, image 3 of 3
    • Pull the tab straight to the left until part releases.
    • Lift up the part to remove completely.
  9. Lenovo IdeaPad Y500 Touchpad  Replacement: step 9, image 1 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 9, image 2 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 9, image 3 of 3
    • To release the DIMM, pull the tabs on either side away from each other simultaneously.
    • The DIMM will pop out on its own.
  10. Lenovo IdeaPad Y500 Touchpad  Replacement: step 10, image 1 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 10, image 2 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 10, image 3 of 3
    • To disconnect the Wi-Fi cables, use a spudger to gently push up under them.
    • Wi-Fi cables are delicate.
  11. Lenovo IdeaPad Y500 Touchpad  Replacement: step 11, image 1 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 11, image 2 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 11, image 3 of 3
    • Using a Phillips #1 screwdriver, remove the two screws.
    • Once screws are out, the card will just pop out.
  12. Lenovo IdeaPad Y500 Touchpad  Replacement: step 12, image 1 of 1
    • Remove three screws using a Phillips #1 screwdriver.
  13. Lenovo IdeaPad Y500 Touchpad  Replacement: step 13, image 1 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 13, image 2 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 13, image 3 of 3
    • With the laptop upside down, open slightly.
    • To remove the keyboard, push the back of the keyboard forward with your thumb while pulling away from the laptop on the other side.
    • You will not be able to pull the keyboard completely away. The cables are still connected to the laptop.
  14. Lenovo IdeaPad Y500 Touchpad  Replacement: step 14, image 1 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 14, image 2 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 14, image 3 of 3
    • To release the cables, use the spudger to push both ends on the side of the cable.
    • Gently pull the cables up to disconnect.
  15. Lenovo IdeaPad Y500 Touchpad  Replacement: step 15, image 1 of 2 Lenovo IdeaPad Y500 Touchpad  Replacement: step 15, image 2 of 2
    • Pull the keyboard up and away from the laptop to remove it.
  16. Lenovo IdeaPad Y500 Touchpad  Replacement, Touchpad: step 16, image 1 of 2 Lenovo IdeaPad Y500 Touchpad  Replacement, Touchpad: step 16, image 2 of 2
    • Remove a total of 8 screws.
    • Red circles are m2.5 x 10 mm flathead screws.
    • Orange circles m2 x 3mm flathead screws.
    • Yellow circle is m2.5 x 4mm flathead screw.
  17. Lenovo IdeaPad Y500 Touchpad  Replacement: step 17, image 1 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 17, image 2 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 17, image 3 of 3
    • Flip up black tabs at the ends of each cable.
    • With fingers, gently remove the cables underneath from their ports.
  18. Lenovo IdeaPad Y500 Touchpad  Replacement: step 18, image 1 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 18, image 2 of 3 Lenovo IdeaPad Y500 Touchpad  Replacement: step 18, image 3 of 3
    • By unlatching the sides and pulling up, remove the top case from the device.
    • Casing is fragile, be careful not to twist when pulling up.
Tatum Hennige
687 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 9
All Time: 618
