Lenovo IdeaPad Y700-15ACZ Display Replacement
  1. Lenovo IdeaPad Y700-15ACZ Display Replacement, Display: step 1, image 1 of 2 Lenovo IdeaPad Y700-15ACZ Display Replacement, Display: step 1, image 2 of 2
    • Remove the border around the screen using a plastic opening tool.
    • When removing the border be careful, the plastic connectors can sometimes break under little amounts of pressure
  2. Lenovo IdeaPad Y700-15ACZ Display Replacement: step 2, image 1 of 3 Lenovo IdeaPad Y700-15ACZ Display Replacement: step 2, image 2 of 3 Lenovo IdeaPad Y700-15ACZ Display Replacement: step 2, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the four screws that secure the display (one screw at each corner).
  3. Lenovo IdeaPad Y700-15ACZ Display Replacement: step 3, image 1 of 2 Lenovo IdeaPad Y700-15ACZ Display Replacement: step 3, image 2 of 2
    • Before you remove or rotate the display, remove the cable connected to the display from the constraints.
  4. Lenovo IdeaPad Y700-15ACZ Display Replacement: step 4, image 1 of 2 Lenovo IdeaPad Y700-15ACZ Display Replacement: step 4, image 2 of 2
    • Rotate the display face down.
    • From the sticker carefully peel down and remove the connection from the display.
    • Attach the ribbon to the new display.
Repeat steps backward to put the computer back together. After you have completed the reassembly, make sure to test the new display by powering on the device.
Colin Burke
109 Reputation
1 Guide authored
IUPUI, Team 3-1, Harley Spring 2023 Member of IUPUI, Team 3-1, Harley Spring 2023
IUPUI-HARLEY-S23S3G1
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 188
