Lenovo IdeaPad Yoga 11S Battery Replacement
  1. Lenovo IdeaPad Yoga 11S Battery Replacement, Top Assembly: step 1, image 1 of 3 Lenovo IdeaPad Yoga 11S Battery Replacement, Top Assembly: step 1, image 2 of 3 Lenovo IdeaPad Yoga 11S Battery Replacement, Top Assembly: step 1, image 3 of 3
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
  2. Lenovo IdeaPad Yoga 11S Battery Replacement, Remove Keyboard: step 2, image 1 of 1
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S Battery Replacement: step 3, image 1 of 1
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S Battery Replacement: step 4, image 1 of 3 Lenovo IdeaPad Yoga 11S Battery Replacement: step 4, image 2 of 3 Lenovo IdeaPad Yoga 11S Battery Replacement: step 4, image 3 of 3
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
  5. Lenovo IdeaPad Yoga 11S Battery Replacement, RAM: step 5, image 1 of 3 Lenovo IdeaPad Yoga 11S Battery Replacement, RAM: step 5, image 2 of 3 Lenovo IdeaPad Yoga 11S Battery Replacement, RAM: step 5, image 3 of 3
    • Locate the RAM module.
    • Locate the tabs on both sides of the RAM module
    • Spread both tabs outward at the same time in order to release the RAM module.
  6. Lenovo IdeaPad Yoga 11S Battery Replacement: step 6, image 1 of 1
    • Grab the RAM module and carefully pull it out from its position.
  7. Lenovo IdeaPad Yoga 11S Battery Replacement, Battery: step 7, image 1 of 1
    • Locate the 1.9mm screw used to hold down the battery.
    • Use a Phillips #0 Screwdriver to remove the screw.
  8. Lenovo IdeaPad Yoga 11S Battery Replacement: step 8, image 1 of 1
    • Use a plastic opening tool to disconnect the battery connector from the motherboard.
  9. Lenovo IdeaPad Yoga 11S Battery Replacement: step 9, image 1 of 1
    • Now that the battery is disconnected from the device, lift the battery and gently remove it from the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
10 other people completed this guide.
Landon Epps
982 Reputation
5 Guides authored
Baylor, Team 7-11, Williams Spring 2015 Member of Baylor, Team 7-11, Williams Spring 2015
BU-WILLIAMS-S15S7G11
3 Members
10 Guides authored
4 Comments
My 11S seems to be a bit different. It has Torx screws instead of phillips for the ten screws on the bottom.
There are two screws under the keyboard holding the top assembly to the bottom. In order to get the keyboard off I had to take out the screws underneath two of the feet on the bottom. Once you take off the keyboard and its ribbon cable, you can detach the three ribbon cables the author of this guide mentions without having to lift up the top assembly first.
I've also noticed there appear to be two different types of batteries for this laptop with the same part number. The first like mine and the one in this teardown have one tab on each of the shorter sides of the battery, while others seem to have two tabs on those same sides of the battery.
Mike G - Reply
Does anyone have a reliable source for a replacement battery?
Brian Simpson - Reply
Great help in replacing my battery. One thing is to be sure to get an original Lenovo battery. The cheap batteries will not work. The 11S has a built in check for third party batteries and the system will not charge the non Lenovo battery.
Mike Rowe - Reply
Mike Rowe is exactly correct, Lenovo Ideapads WILL NOT accept 3rd party batteries.
Bobby Gorden - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 55
All Time: 50,269
