Introduction
Replacing the RAM module with a larger capacity one is a easy way to speed up your computer. Make sure the new RAM module is compatible before you install it.
Position the laptop so that the bottom enclosure is facing upward.
Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
Use an opening tool to carefully pry up the rubber pads.
Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
Flip the laptop over and swing open the display.
Lift the edge of the keyboard closest to the trackpad up.
Carefully disconnect keyboard ribbon cable from the laptop.
Remove the keyboard.
Locate the RAM module.
Locate the tabs on both sides of the RAM module
Spread both tabs outward at the same time in order to release the RAM module.
6 other people completed this guide.
2 Comments
Excelente… easy and simply.
At Step 3. Replace the memory now that it is exposed. You don't have to do steps 4-5, I don't think you have to remove the 10 small screws either.
Just the Philips under the foot tabs and carefully remove the keyboard, pull the tabs back that secure the memory and replace with new memory.
