Lenovo IdeaTab A1000L Battery Replacement
  1. Lenovo IdeaTab A1000L Battery Replacement, Battery: step 1, image 1 of 3 Lenovo IdeaTab A1000L Battery Replacement, Battery: step 1, image 2 of 3 Lenovo IdeaTab A1000L Battery Replacement, Battery: step 1, image 3 of 3
    • Be sure to power off your device before taking it apart.
    • Locate the small tab, marked with the lock symbol on the upper right hand of your IdeaTab above the volume control buttons. Use your fingernail to gently loosen this tab.
    • Use your Phillips #000 screwdriver and remove the 3.5mm screw and put it aside.
    • Using your blue, plastic opening tool, begin to gently pry the back panel away from the front panel starting by where the screw was.
  2. Lenovo IdeaTab A1000L Battery Replacement: step 2, image 1 of 3 Lenovo IdeaTab A1000L Battery Replacement: step 2, image 2 of 3 Lenovo IdeaTab A1000L Battery Replacement: step 2, image 3 of 3
    • Locate the black back plate, above the battery.
    • Using a Phillips #000 screwdriver remove the 7 silver 3.5mm screws from the back plate.
    • Next, with the same screwdriver, remove the black 4.1mm screw.
    • Gently remove the back plate from the device.
  3. Lenovo IdeaTab A1000L Battery Replacement: step 3, image 1 of 3 Lenovo IdeaTab A1000L Battery Replacement: step 3, image 2 of 3 Lenovo IdeaTab A1000L Battery Replacement: step 3, image 3 of 3
    • Use the plastic opening tool to disconnect the battery wires from the system board. Slide your opening tool under the white plastic piece and pry it up.
    • Again, use the plastic opening tool to loosen the battery from the device by lifting up on the battery on all sides. This will detach the battery from the adhesive.
    • Gently place the battery aside.
10 other people completed this guide.
Peter Newell
627 Reputation
2 Guides authored
Cal Poly, Team 7-21, Regan Spring 2014 Member of Cal Poly, Team 7-21, Regan Spring 2014
CPSU-REGAN-S14S7G21
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 22,984
