Lenovo IdeaTab A2109 Camera Assembly Replacement
  1. Lenovo IdeaTab A2109 Camera Assembly Replacement, Camera Assembly: step 1, image 1 of 1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • Locate the small indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool in this indentation, under the middle of the cover as shown.
    • Pry up and push to remove the cover.
  2. Lenovo IdeaTab A2109 Camera Assembly Replacement: step 2, image 1 of 2 Lenovo IdeaTab A2109 Camera Assembly Replacement: step 2, image 2 of 2
    • Remove the following two screws:
    • M3.0 x 3.0 mm #00 phillips screws (black)
  3. Lenovo IdeaTab A2109 Camera Assembly Replacement: step 3, image 1 of 3 Lenovo IdeaTab A2109 Camera Assembly Replacement: step 3, image 2 of 3 Lenovo IdeaTab A2109 Camera Assembly Replacement: step 3, image 3 of 3
    • Pry open the front and rear faces using a plastic opening tool.
    • It may take a little force to separate the front and rear faces of the device.
    • Slide the plastic opening tool to one corner.
    • Place another plastic opening tool into the gap and slide it to the opposite corner as shown.
    • Pull the rear cover up and back to separate it from front face of the device.
  4. Lenovo IdeaTab A2109 Camera Assembly Replacement: step 4, image 1 of 1
    • Slide the rear camera ribbon from the system board.
    • Pull up on the black plastic lock on the system board for the front camera and slide the ribbon out.
    • Now, you are ready to remove the front and rear facing cameras.
Abigail Bertholf
521 Reputation
1 Guide authored
Cal Poly, Team 7-19, Regan Spring 2014 Member of Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 602
