Lenovo IdeaTab A2109 IO Board Replacement
  1. Lenovo IdeaTab A2109 IO Board Replacement, Battery: step 1, image 1 of 1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 IO Board Replacement: step 2, image 1 of 2 Lenovo IdeaTab A2109 IO Board Replacement: step 2, image 2 of 2
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 IO Board Replacement: step 3, image 1 of 2 Lenovo IdeaTab A2109 IO Board Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 IO Board Replacement: step 4, image 1 of 2 Lenovo IdeaTab A2109 IO Board Replacement: step 4, image 2 of 2
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 IO Board Replacement: step 5, image 1 of 2 Lenovo IdeaTab A2109 IO Board Replacement: step 5, image 2 of 2
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
  6. Lenovo IdeaTab A2109 IO Board Replacement, System Board: step 6, image 1 of 3 Lenovo IdeaTab A2109 IO Board Replacement, System Board: step 6, image 2 of 3 Lenovo IdeaTab A2109 IO Board Replacement, System Board: step 6, image 3 of 3
    • Remove three silver 1.8 mm Phillips #00 screws.
  7. Lenovo IdeaTab A2109 IO Board Replacement: step 7, image 1 of 3 Lenovo IdeaTab A2109 IO Board Replacement: step 7, image 2 of 3 Lenovo IdeaTab A2109 IO Board Replacement: step 7, image 3 of 3
    Buy
    • Use tweezers to flip up the small black plastic locks on all four connections.
    • Carefully remove each of the exposed ribbons.
  8. Lenovo IdeaTab A2109 IO Board Replacement: step 8, image 1 of 2 Lenovo IdeaTab A2109 IO Board Replacement: step 8, image 2 of 2
    • Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing.
  9. Lenovo IdeaTab A2109 IO Board Replacement: step 9, image 1 of 2 Lenovo IdeaTab A2109 IO Board Replacement: step 9, image 2 of 2
    • Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector.
  10. Lenovo IdeaTab A2109 IO Board Replacement: step 10, image 1 of 3 Lenovo IdeaTab A2109 IO Board Replacement: step 10, image 2 of 3 Lenovo IdeaTab A2109 IO Board Replacement: step 10, image 3 of 3
    • Disconnect the HDMI connection with the system board
    • Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free.
    • Slide out the system board from its housing tab on the upper right corner.
    • Pull the board slowly away from the tab, and it will pop out.
  11. Lenovo IdeaTab A2109 IO Board Replacement, IO Board: step 11, image 1 of 2 Lenovo IdeaTab A2109 IO Board Replacement, IO Board: step 11, image 2 of 2
    • Remove the following two screws:
    • M 5.3 x 1.75 mm #00 phillips screws (silver)
  12. Lenovo IdeaTab A2109 IO Board Replacement: step 12, image 1 of 1
    Buy
    • Once the screws are out, use the tweezers to pull the board straight out.
9 other people completed this guide.
Brian
565 Reputation
2 Guides authored
Cal Poly, Team 7-19, Regan Spring 2014 Member of Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Members
15 Guides authored
6 Comments
Great guide but make sure you REMOVE THE AUX SD CARD FIRST if installed or you will break the card and or card slot.
Other than that, no problems. I got the io board for $26 and I put it in for free.
James Bush - Reply
I need an io board for cheap... I might have to make a guide on how to attempt to repair io card without proper tools and a filed down soldering iron tip
Ember Leona - Reply
Thank you this was helpful. I think I fixed my screen flickers the LCD ribbon is under the battery and the ribbon from the volume board on the right I think that's related to the screen rotation lock. Those needed to be flipped up and reseated. Thanks
Ember Leona - Reply
Thanks Very much
the guide is very clear
i have done the job successfully
omimh - Reply
Excelente guía. Muchas gracias.
Larry Pacheco - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 4,949
