Lenovo IdeaTab S2109A-F Battery Replacement
  1. Lenovo IdeaTab S2109A-F Battery Replacement, Battery: step 1, image 1 of 2 Lenovo IdeaTab S2109A-F Battery Replacement, Battery: step 1, image 2 of 2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Battery Replacement: step 2, image 1 of 2 Lenovo IdeaTab S2109A-F Battery Replacement: step 2, image 2 of 2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Battery Replacement: step 3, image 1 of 1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
Caelen
228 Reputation
2 Guides authored
USF Tampa, Team 17-3, Watkins Winter 2015 Member of USF Tampa, Team 17-3, Watkins Winter 2015
USFT-WATKINS-W15S17G3
4 Members
10 Guides authored
2 Comments
Folks this is not easy! The first thing that happened, my screen broke. Then it took about thirty minutes to finally get the back off and the on-off swithch was damaged. Take it to a shop and let them do the damage, then its up to them to pay for it or replace it. I’m now out a s2109 Lenovo tablet because the instructions said easy. Maybe his was. This one sure as heck was not!!
jangoodman - Reply
Theres some screws missing from the directions, under the speakers and in a hole along one side. Tiny torx on the side.
Devin Holland - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,563
