Lenovo IdeaTab S2109A-F Speaker Replacement
  1. Lenovo IdeaTab S2109A-F Speaker Replacement, Battery: step 1, image 1 of 2 Lenovo IdeaTab S2109A-F Speaker Replacement, Battery: step 1, image 2 of 2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Speaker Replacement: step 2, image 1 of 2 Lenovo IdeaTab S2109A-F Speaker Replacement: step 2, image 2 of 2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Speaker Replacement: step 3, image 1 of 1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
  4. Lenovo IdeaTab S2109A-F Speaker Replacement, Speaker: step 4, image 1 of 2 Lenovo IdeaTab S2109A-F Speaker Replacement, Speaker: step 4, image 2 of 2
    • Remove the ten 2 mm black screws from the edges of the system board with a Phillips #00 screwdriver.
  5. Lenovo IdeaTab S2109A-F Speaker Replacement: step 5, image 1 of 1
    • Disconnect the gold connector by lifting the latch with the plastic opening tool.
  6. Lenovo IdeaTab S2109A-F Speaker Replacement: step 6, image 1 of 2 Lenovo IdeaTab S2109A-F Speaker Replacement: step 6, image 2 of 2
    • Pull up on the L-shaped board.
    • The bottom and top connection points should disconnect.
  7. Lenovo IdeaTab S2109A-F Speaker Replacement: step 7, image 1 of 2 Lenovo IdeaTab S2109A-F Speaker Replacement: step 7, image 2 of 2
    • Remove the seven 2 mm black screws connecting the speakers using the Phillips #00 screwdriver.
  8. Lenovo IdeaTab S2109A-F Speaker Replacement: step 8, image 1 of 3 Lenovo IdeaTab S2109A-F Speaker Replacement: step 8, image 2 of 3 Lenovo IdeaTab S2109A-F Speaker Replacement: step 8, image 3 of 3
    • Lift the disconnected speakers from their resting position.
    • Grab the red and black cable with your index finger and thumb.
  9. Lenovo IdeaTab S2109A-F Speaker Replacement: step 9, image 1 of 1
    • Pull up on the connection to disconnect the speakers.
Caelen
228 Reputation
2 Guides authored
USF Tampa, Team 17-3, Watkins Winter 2015 Member of USF Tampa, Team 17-3, Watkins Winter 2015
USFT-WATKINS-W15S17G3
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 449
