Lenovo Ideapad 110S-11IBR Speaker Replacement
  1. Lenovo Ideapad 110S-11IBR Speaker Replacement, Battery: step 1, image 1 of 1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Speaker Replacement: step 2, image 1 of 2 Lenovo Ideapad 110S-11IBR Speaker Replacement: step 2, image 2 of 2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Speaker Replacement: step 3, image 1 of 2 Lenovo Ideapad 110S-11IBR Speaker Replacement: step 3, image 2 of 2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Speaker Replacement: step 4, image 1 of 1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Speaker Replacement: step 5, image 1 of 2 Lenovo Ideapad 110S-11IBR Speaker Replacement: step 5, image 2 of 2
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Speaker Replacement, Speaker: step 6, image 1 of 1
    • Use your fingers to gently remove the speaker connector from its socket.
  7. Lenovo Ideapad 110S-11IBR Speaker Replacement: step 7, image 1 of 2 Lenovo Ideapad 110S-11IBR Speaker Replacement: step 7, image 2 of 2
    • Unscrew the four 4mm Phillips screws.
  8. Lenovo Ideapad 110S-11IBR Speaker Replacement: step 8, image 1 of 1
    • Pull the right speaker carefully under the ribbon cable.
  9. Lenovo Ideapad 110S-11IBR Speaker Replacement: step 9, image 1 of 1
    • Lift the the left speaker to finish.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 688
