Lenovo Ideapad 110S-11IBR Thermal paste Replacement
  1. Lenovo Ideapad 110S-11IBR Thermal paste Replacement, Battery: step 1, image 1 of 1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Thermal paste Replacement: step 2, image 1 of 2 Lenovo Ideapad 110S-11IBR Thermal paste Replacement: step 2, image 2 of 2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Thermal paste Replacement: step 3, image 1 of 2 Lenovo Ideapad 110S-11IBR Thermal paste Replacement: step 3, image 2 of 2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Thermal paste Replacement: step 4, image 1 of 1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Thermal paste Replacement: step 5, image 1 of 2 Lenovo Ideapad 110S-11IBR Thermal paste Replacement: step 5, image 2 of 2
    • Lift the battery up and out of the device.
    • once the battery is removed unscrew the coldplate and pull it free from the mainboard.
    • Using Isopropyl alcohol and a microfiber cloth, wipe away the old thermal compound, make sure to clean the coldplate and CPU die.
    • apply about half a gram of non-conductive thermal compound to the heat spreader of the CPU and replace the coldplate pressing down gently.
[deleted]
367 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 199
