Lenovo Ideapad 110S-11IBR Touchpad Replacement
  1. Lenovo Ideapad 110S-11IBR Touchpad Replacement, Battery: step 1, image 1 of 1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Touchpad Replacement: step 2, image 1 of 2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: step 2, image 2 of 2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Touchpad Replacement: step 3, image 1 of 2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: step 3, image 2 of 2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Touchpad Replacement: step 4, image 1 of 1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Touchpad Replacement: step 5, image 1 of 2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: step 5, image 2 of 2
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Touchpad Replacement, Touchpad: step 6, image 1 of 1
    • Use a Phillips #0 screwdriver to remove four 2.7 mm screws from the touch pad clicker assembly.
  7. Lenovo Ideapad 110S-11IBR Touchpad Replacement: step 7, image 1 of 1
    • Remove the clicker assembly.
  8. Lenovo Ideapad 110S-11IBR Touchpad Replacement: step 8, image 1 of 2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: step 8, image 2 of 2
    • Use a plastic opening tool to remove the touch pad.
    • Time must be taken to work the adhesive without causing damage to the touch pad.
Samaa Aldar
181 Reputation
2 Guides authored
IUPUI, Team S11-G11, Wilson Spring 2019 Member of IUPUI, Team S11-G11, Wilson Spring 2019
IUPUI-WILSON-S19S11G11
2 Members
6 Guides authored
One Comment
i appreciate the tear down. I would like to see the screws that came out of the holes instead of empty screw holes though.
daldal - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 1,320
