Lenovo Ideapad 320-14ISK RAM Replacement
  1. Lenovo Ideapad 320-14ISK RAM Replacement, Prepare the equipment: step 1, image 1 of 3 Lenovo Ideapad 320-14ISK RAM Replacement, Prepare the equipment: step 1, image 2 of 3 Lenovo Ideapad 320-14ISK RAM Replacement, Prepare the equipment: step 1, image 3 of 3
    • Disconnect the charger and turn off the equipment.
  2. Lenovo Ideapad 320-14ISK RAM Replacement, Remove optical drive: step 2, image 1 of 3 Lenovo Ideapad 320-14ISK RAM Replacement, Remove optical drive: step 2, image 2 of 3 Lenovo Ideapad 320-14ISK RAM Replacement, Remove optical drive: step 2, image 3 of 3
    • Turn the device over.
    • With a Phillips screwdriver, remove the screw pointed out in the image.
    • Slide the optical drive outward until it is removed completely.
    • Set aside.
  3. Lenovo Ideapad 320-14ISK RAM Replacement, Opening the laptop: step 3, image 1 of 3 Lenovo Ideapad 320-14ISK RAM Replacement, Opening the laptop: step 3, image 2 of 3 Lenovo Ideapad 320-14ISK RAM Replacement, Opening the laptop: step 3, image 3 of 3
    • Remove the 12 remaining screws. Set them aside orderly.
    • With a plastic spudger, release the tabs that are found below the optical drive.
    • Continues releasing all of the tabs at the edges until the base of the laptop breaks loose.
    • Set the base aside.
  4. Lenovo Ideapad 320-14ISK RAM Replacement, Remove the existent RAM: step 4, image 1 of 3 Lenovo Ideapad 320-14ISK RAM Replacement, Remove the existent RAM: step 4, image 2 of 3 Lenovo Ideapad 320-14ISK RAM Replacement, Remove the existent RAM: step 4, image 3 of 3
    • You may skip this step if there is no RAM installed previously.
    • Locate and open the tabs on the sides of the RAM. This will cause the RAM to become loose and take a diagonal position.
    • Remove the RAM in the same diagonal direction.
  5. Lenovo Ideapad 320-14ISK RAM Replacement, Install new RAM.: step 5, image 1 of 3 Lenovo Ideapad 320-14ISK RAM Replacement, Install new RAM.: step 5, image 2 of 3 Lenovo Ideapad 320-14ISK RAM Replacement, Install new RAM.: step 5, image 3 of 3
    • Insert translation here
Congratulations! You installed your new RAM memory. Now, reassemble the laptop by following steps 1, 2 and 3 in reverse and enjoy your upgraded laptop.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Franco Iván Bello Rojas
869 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 1,343
