Lenovo Ideapad 320-15ABR Back Panel Replacement
  1. Lenovo Ideapad 320-15ABR Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Back Panel Replacement: step 2, image 1 of 3 Lenovo Ideapad 320-15ABR Back Panel Replacement: step 2, image 2 of 3 Lenovo Ideapad 320-15ABR Back Panel Replacement: step 2, image 3 of 3
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Back Panel Replacement: step 3, image 1 of 2 Lenovo Ideapad 320-15ABR Back Panel Replacement: step 3, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Back Panel Replacement: step 4, image 1 of 3 Lenovo Ideapad 320-15ABR Back Panel Replacement: step 4, image 2 of 3 Lenovo Ideapad 320-15ABR Back Panel Replacement: step 4, image 3 of 3
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Back Panel Replacement: step 5, image 1 of 3 Lenovo Ideapad 320-15ABR Back Panel Replacement: step 5, image 2 of 3 Lenovo Ideapad 320-15ABR Back Panel Replacement: step 5, image 3 of 3
    • Remove the back panel by pulling it up and away from the laptop.
3 other people completed this guide.
One Comment
How Is solved Twisted screw and broken inside the frame
For laptop ip520
mohsen JUVE - Reply
Past 24 Hours: 1
Past 7 Days: 29
Past 30 Days: 71
All Time: 14,028
