Lenovo Ideapad 320-15ABR Battery Replacement
  1. Lenovo Ideapad 320-15ABR Battery Replacement, Back Panel: step 1, image 1 of 1
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Battery Replacement: step 2, image 1 of 3 Lenovo Ideapad 320-15ABR Battery Replacement: step 2, image 2 of 3 Lenovo Ideapad 320-15ABR Battery Replacement: step 2, image 3 of 3
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Battery Replacement: step 3, image 1 of 2 Lenovo Ideapad 320-15ABR Battery Replacement: step 3, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Battery Replacement: step 4, image 1 of 3 Lenovo Ideapad 320-15ABR Battery Replacement: step 4, image 2 of 3 Lenovo Ideapad 320-15ABR Battery Replacement: step 4, image 3 of 3
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Battery Replacement: step 5, image 1 of 3 Lenovo Ideapad 320-15ABR Battery Replacement: step 5, image 2 of 3 Lenovo Ideapad 320-15ABR Battery Replacement: step 5, image 3 of 3
    • Remove the back panel by pulling it up and away from the laptop.
  6. Lenovo Ideapad 320-15ABR Battery Replacement, Battery: step 6, image 1 of 1
    • Remove the four 6mm screws using the Phillips #1 screwdriver.
  7. Lenovo Ideapad 320-15ABR Battery Replacement: step 7, image 1 of 2 Lenovo Ideapad 320-15ABR Battery Replacement: step 7, image 2 of 2
    • Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
  8. Lenovo Ideapad 320-15ABR Battery Replacement: step 8, image 1 of 1
    • Remove the battery.
26 other people completed this guide.
4 Comments
hi
can i change the original battery with a more powerful battery?
amin - Reply
Votre explication est très bien détaillée et très explicite. Merci beaucoup vous m'avez vraiment aidé.
Ulrich Foudjin - Reply
I can't get past the first step...pulling out the optical card. The rest I think I can do because I have done things like this before. I unscrewed the screw bu can't pull it out.
Peg Thompson - Reply
Unclip the tiny clips from where you removed the optical card. The back will come off
TopStuff Anime -
Past 24 Hours: 15
Past 7 Days: 121
Past 30 Days: 580
All Time: 82,626
