Lenovo Ideapad 320-15ABR Fan Replacement
  1. Lenovo Ideapad 320-15ABR Fan Replacement, Back Panel: step 1, image 1 of 1
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Fan Replacement: step 2, image 1 of 3 Lenovo Ideapad 320-15ABR Fan Replacement: step 2, image 2 of 3 Lenovo Ideapad 320-15ABR Fan Replacement: step 2, image 3 of 3
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Fan Replacement: step 3, image 1 of 2 Lenovo Ideapad 320-15ABR Fan Replacement: step 3, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Fan Replacement: step 4, image 1 of 3 Lenovo Ideapad 320-15ABR Fan Replacement: step 4, image 2 of 3 Lenovo Ideapad 320-15ABR Fan Replacement: step 4, image 3 of 3
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Fan Replacement: step 5, image 1 of 3 Lenovo Ideapad 320-15ABR Fan Replacement: step 5, image 2 of 3 Lenovo Ideapad 320-15ABR Fan Replacement: step 5, image 3 of 3
    • Remove the back panel by pulling it up and away from the laptop.
  6. Lenovo Ideapad 320-15ABR Fan Replacement, Battery: step 6, image 1 of 1
    • Remove the four 6mm screws using the Phillips #1 screwdriver.
  7. Lenovo Ideapad 320-15ABR Fan Replacement: step 7, image 1 of 2 Lenovo Ideapad 320-15ABR Fan Replacement: step 7, image 2 of 2
    • Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
  8. Lenovo Ideapad 320-15ABR Fan Replacement: step 8, image 1 of 1
    • Remove the battery.
  9. Lenovo Ideapad 320-15ABR Fan Replacement, Fan: step 9, image 1 of 2 Lenovo Ideapad 320-15ABR Fan Replacement, Fan: step 9, image 2 of 2
    • Disconnect black and grey wires by simply giving them a light tug.
  10. Lenovo Ideapad 320-15ABR Fan Replacement: step 10, image 1 of 1
    • Remove the 6mm Phillips #1 screw connecting the fan to the laptop.
  11. Lenovo Ideapad 320-15ABR Fan Replacement: step 11, image 1 of 3 Lenovo Ideapad 320-15ABR Fan Replacement: step 11, image 2 of 3 Lenovo Ideapad 320-15ABR Fan Replacement: step 11, image 3 of 3
    • Lift the fan slightly and straight upward and unwind the black and grey wires from the fan.
  12. Lenovo Ideapad 320-15ABR Fan Replacement: step 12, image 1 of 1
    • Identify the red, black, yellow, and brown wire coming from the back of the fan connecting to the motherboard with a white connector piece.
  13. Lenovo Ideapad 320-15ABR Fan Replacement: step 13, image 1 of 2 Lenovo Ideapad 320-15ABR Fan Replacement: step 13, image 2 of 2
    • Slowly pull and wiggle the white connector piece until it comes loose from the laptop.
  14. Lenovo Ideapad 320-15ABR Fan Replacement: step 14, image 1 of 1
    • Replace the new fan.
0 Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 38
All Time: 5,108
