Lenovo Ideapad 330-15ARR Fan Assembly Replacement
  1. Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Lower Case: step 1, image 1 of 1
    • Remove all Phillips #0 screws securing the case to the laptop.
  2. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: step 2, image 1 of 2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: step 2, image 2 of 2
    • Pry all edges off of the laptop with the opening tool until the lower case releases.
    • Remove the lower case.
  3. Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Fan Assembly: step 3, image 1 of 2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Fan Assembly: step 3, image 2 of 2
    • Unscrew all three captive screws attaching the heat sink to the motherboard with a Phillips #0 screwdriver.
    • These screws stay attached to the heatsink, so do not attempt to remove them.
  4. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: step 4, image 1 of 2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: step 4, image 2 of 2
    • Remove the three Phillips #0 screws securing the fan assembly.
  5. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: step 5, image 1 of 3 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: step 5, image 2 of 3 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: step 5, image 3 of 3
    • Take the wires in your hand, and firmly but gently pull it out of its port.
    • Lift the fan assembly out of the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 379
