Lenovo Ideapad Flex 4-1570 Battery Replacement
  1. Lenovo Ideapad Flex 4-1570 Battery Replacement, Back Panel: step 1, image 1 of 1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Battery Replacement: step 2, image 1 of 1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Battery Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Battery Replacement, Battery: step 4, image 1 of 2 Lenovo Ideapad Flex 4-1570 Battery Replacement, Battery: step 4, image 2 of 2
    • Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery.
    • Do not pry or pull on the socket itself or you risk damaging the motherboard.
  5. Lenovo Ideapad Flex 4-1570 Battery Replacement: step 5, image 1 of 1
    • Remove the three 4 mm screws using a T5 Torx Screwdriver.
  6. Lenovo Ideapad Flex 4-1570 Battery Replacement: step 6, image 1 of 1
    • Remove the battery.
2 other people completed this guide.
Isaiah Vang
669 Reputation
6 Guides authored
UW Stout, Team S6-G6, Ogden Fall 2018 Member of UW Stout, Team S6-G6, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G6
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 29
All Time: 1,677
