Lenovo Ideapad Flex 4-1570 Hard Drive Replacement
  1. Lenovo Ideapad Flex 4-1570 Hard Drive Replacement, Back Panel: step 1, image 1 of 1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Hard Drive Replacement: step 2, image 1 of 1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Hard Drive Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Lenovo Ideapad Flex 4-1570 Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
    • Remove the three 4 mm screws using a Phillips #00 screwdriver.
  5. Lenovo Ideapad Flex 4-1570 Hard Drive Replacement: step 5, image 1 of 1
    • Lift the hard drive up and out.
Isaiah Vang
669 Reputation
6 Guides authored
UW Stout, Team S6-G6, Ogden Fall 2018 Member of UW Stout, Team S6-G6, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G6
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 30
All Time: 1,473
