Introduction
Use this guide to replace the battery in your Lenovo IdeaPad gaming 3 15ACH6.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Use a Phillips screwdriver to remove the 10 screws securing the lower case:
Six 12 mm screws
Four 4.5 mm screws
Insert an opening pick between the lower case and the chassis on the front right edge.
Slide the pick along the front edge to release the clips securing the lower case.
Continue sliding the opening pick along the left and right edges to release the remaining clips.
Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
Use your Phillips screwdriver to remove the four 5.6 mm-long screws securing the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo IdeaPad answers community for help.
4 other people completed this guide.
