Lenovo Legion 5 15ACH6H Back Cover Replacement
  1. Lenovo Legion 5 15ACH6H Back Cover Replacement, Back cover removal: step 1, image 1 of 2 Lenovo Legion 5 15ACH6H Back Cover Replacement, Back cover removal: step 1, image 2 of 2
    • Use a Phillips screwdriver to remove the following ten screws securing the back cover to frame:
    • Six 12.5 mm PH1 screws
    • Four 4.7 mm PH1 screws
  2. Lenovo Legion 5 15ACH6H Back Cover Replacement, Release the front clips: step 2, image 1 of 3 Lenovo Legion 5 15ACH6H Back Cover Replacement, Release the front clips: step 2, image 2 of 3 Lenovo Legion 5 15ACH6H Back Cover Replacement, Release the front clips: step 2, image 3 of 3
    • Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
  3. Lenovo Legion 5 15ACH6H Back Cover Replacement: step 3, image 1 of 3 Lenovo Legion 5 15ACH6H Back Cover Replacement: step 3, image 2 of 3 Lenovo Legion 5 15ACH6H Back Cover Replacement: step 3, image 3 of 3
    • Angle the pick to about 30˚.
    • Slide the pick along the front edge to release the clips securing the back cover to the frame.
  4. Lenovo Legion 5 15ACH6H Back Cover Replacement, Release the left clips: step 4, image 1 of 2 Lenovo Legion 5 15ACH6H Back Cover Replacement, Release the left clips: step 4, image 2 of 2
    • Insert the edge of an opening pick between the back cover and the frame on the right edge.
    • Angle the pick to about 30˚ and slide down the left edge to release the clips.
  5. Lenovo Legion 5 15ACH6H Back Cover Replacement, Release the right clips: step 5, image 1 of 2 Lenovo Legion 5 15ACH6H Back Cover Replacement, Release the right clips: step 5, image 2 of 2
    • Repeat the same procedure on the left edge to release the clips.
  6. Lenovo Legion 5 15ACH6H Back Cover Replacement, Release the right vent clips: step 6, image 1 of 3 Lenovo Legion 5 15ACH6H Back Cover Replacement, Release the right vent clips: step 6, image 2 of 3 Lenovo Legion 5 15ACH6H Back Cover Replacement, Release the right vent clips: step 6, image 3 of 3
    • Position the laptop vertically so you can easily access the plastic vents.
    • Slide the rounded edge of an opening pick between the frame and the plastic vents on the left side near the USB-C port.
    • Rotate the pick so that it is positioned on top of the plastic vents.
  7. Lenovo Legion 5 15ACH6H Back Cover Replacement: step 7, image 1 of 2 Lenovo Legion 5 15ACH6H Back Cover Replacement: step 7, image 2 of 2
    • Push the pick between the frame and plastic vents.
    • Slide the pick along the top edge of the plastic vents to release the clips.
  8. Lenovo Legion 5 15ACH6H Back Cover Replacement, Release the left vent clips: step 8, image 1 of 3 Lenovo Legion 5 15ACH6H Back Cover Replacement, Release the left vent clips: step 8, image 2 of 3 Lenovo Legion 5 15ACH6H Back Cover Replacement, Release the left vent clips: step 8, image 3 of 3
    • Slide the opening pick between the frame and the plastic vents on the right side near the USB-A port.
  9. Lenovo Legion 5 15ACH6H Back Cover Replacement: step 9, image 1 of 2 Lenovo Legion 5 15ACH6H Back Cover Replacement: step 9, image 2 of 2
  10. Lenovo Legion 5 15ACH6H Back Cover Replacement, Remove the back cover: step 10, image 1 of 3 Lenovo Legion 5 15ACH6H Back Cover Replacement, Remove the back cover: step 10, image 2 of 3 Lenovo Legion 5 15ACH6H Back Cover Replacement, Remove the back cover: step 10, image 3 of 3
    • Lift the back cover up and remove it from the chassis.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion answers community for help.
Chayton Ritter
19,544 Reputation
105 Guides authored
Guide Team Member of Guide Team
Staff
8 Members
8,213 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 46
Past 30 Days: 299
All Time: 4,784
