Lenovo Legion 5 17ACH6H Battery Replacement
  1. Lenovo Legion 5 17ACH6H Battery Replacement, Back cover removal: step 1, image 1 of 2 Lenovo Legion 5 17ACH6H Battery Replacement, Back cover removal: step 1, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the following ten screws securing the back cover to the frame:
    • Six 12.8 mm PH1 screws
    • Four 4.6 mm PH1 screws
  2. Lenovo Legion 5 17ACH6H Battery Replacement, Release the front clips: step 2, image 1 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Release the front clips: step 2, image 2 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Release the front clips: step 2, image 3 of 3
    • Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
    • Angle the pick to about 45˚.
  3. Lenovo Legion 5 17ACH6H Battery Replacement: step 3, image 1 of 3 Lenovo Legion 5 17ACH6H Battery Replacement: step 3, image 2 of 3 Lenovo Legion 5 17ACH6H Battery Replacement: step 3, image 3 of 3
    • Slide the pick along the front edge to release the clips securing the back cover to the frame.
  4. Lenovo Legion 5 17ACH6H Battery Replacement, Release the right clips: step 4, image 1 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Release the right clips: step 4, image 2 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Release the right clips: step 4, image 3 of 3
    • Insert the edge of an opening pick between the back cover and the frame on the right edge.
    • Angle the pick to about 30˚ and slide down the left edge to release the clips.
  5. Lenovo Legion 5 17ACH6H Battery Replacement, Release the left clips: step 5, image 1 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Release the left clips: step 5, image 2 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Release the left clips: step 5, image 3 of 3
    • Repeat the same procedure on the left edge to release the clips.
  6. Lenovo Legion 5 17ACH6H Battery Replacement, Release the right vent clips: step 6, image 1 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Release the right vent clips: step 6, image 2 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Release the right vent clips: step 6, image 3 of 3
    • Slide the opening pick between the frame and the plastic vents on the right side near the USB-A port.
    • Rotate the pick so that it is positioned on top of the plastic vents.
    • If the pick is difficult to insert, position the laptop vertically to reduce the weight on the back cover.
  7. Lenovo Legion 5 17ACH6H Battery Replacement: step 7, image 1 of 2 Lenovo Legion 5 17ACH6H Battery Replacement: step 7, image 2 of 2
    • Push the pick between the frame and plastic vents.
    • Slide the pick along the top edge of the plastic vents to release the clips.
  8. Lenovo Legion 5 17ACH6H Battery Replacement, Release the left vent clips: step 8, image 1 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Release the left vent clips: step 8, image 2 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Release the left vent clips: step 8, image 3 of 3
    • Slide the opening pick between the frame and the plastic vents on the left side near the USB-C port.
  9. Lenovo Legion 5 17ACH6H Battery Replacement, Remove the back cover: step 9, image 1 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Remove the back cover: step 9, image 2 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Remove the back cover: step 9, image 3 of 3
    • Lift the back cover up and remove it from the chassis.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  10. Lenovo Legion 5 17ACH6H Battery Replacement, Disconnect the battery: step 10, image 1 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Disconnect the battery: step 10, image 2 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Disconnect the battery: step 10, image 3 of 3
    • Use the pointed end of a spudger to push each side of the battery connector to loosen it.
  11. Lenovo Legion 5 17ACH6H Battery Replacement: step 11, image 1 of 2 Lenovo Legion 5 17ACH6H Battery Replacement: step 11, image 2 of 2
    • Use the flat end of a spudger to push out and disconnect battery cable.
  12. Lenovo Legion 5 17ACH6H Battery Replacement, Unfasten the battery: step 12, image 1 of 2 Lenovo Legion 5 17ACH6H Battery Replacement, Unfasten the battery: step 12, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the six 5 mm-long screws securing the battery.
  13. Lenovo Legion 5 17ACH6H Battery Replacement, Remove the battery: step 13, image 1 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Remove the battery: step 13, image 2 of 3 Lenovo Legion 5 17ACH6H Battery Replacement, Remove the battery: step 13, image 3 of 3
    • Lift the battery straight out of its recess and remove it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
129,330 Reputation
600 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,077 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 69
All Time: 1,393
