Lenovo Legion 5 17ACH6H Left SSD Replacement
  1. Lenovo Legion 5 17ACH6H Left SSD Replacement, Back cover removal: step 1, image 1 of 2 Lenovo Legion 5 17ACH6H Left SSD Replacement, Back cover removal: step 1, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the following ten screws securing the back cover to the frame:
    • Six 12.8 mm PH1 screws
    • Four 4.6 mm PH1 screws
  2. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the front clips: step 2, image 1 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the front clips: step 2, image 2 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the front clips: step 2, image 3 of 3
    • Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
    • Angle the pick to about 45˚.
  3. Lenovo Legion 5 17ACH6H Left SSD Replacement: step 3, image 1 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement: step 3, image 2 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement: step 3, image 3 of 3
    • Slide the pick along the front edge to release the clips securing the back cover to the frame.
  4. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right clips: step 4, image 1 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right clips: step 4, image 2 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right clips: step 4, image 3 of 3
    • Insert the edge of an opening pick between the back cover and the frame on the right edge.
    • Angle the pick to about 30˚ and slide down the left edge to release the clips.
  5. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left clips: step 5, image 1 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left clips: step 5, image 2 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left clips: step 5, image 3 of 3
    • Repeat the same procedure on the left edge to release the clips.
  6. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right vent clips: step 6, image 1 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right vent clips: step 6, image 2 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right vent clips: step 6, image 3 of 3
    • Slide the opening pick between the frame and the plastic vents on the right side near the USB-A port.
    • Rotate the pick so that it is positioned on top of the plastic vents.
    • If the pick is difficult to insert, position the laptop vertically to reduce the weight on the back cover.
  7. Lenovo Legion 5 17ACH6H Left SSD Replacement: step 7, image 1 of 2 Lenovo Legion 5 17ACH6H Left SSD Replacement: step 7, image 2 of 2
    • Push the pick between the frame and plastic vents.
    • Slide the pick along the top edge of the plastic vents to release the clips.
  8. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left vent clips: step 8, image 1 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left vent clips: step 8, image 2 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left vent clips: step 8, image 3 of 3
    • Slide the opening pick between the frame and the plastic vents on the left side near the USB-C port.
  9. Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the back cover: step 9, image 1 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the back cover: step 9, image 2 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the back cover: step 9, image 3 of 3
    • Lift the back cover up and remove it from the chassis.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  10. Lenovo Legion 5 17ACH6H Left SSD Replacement, Disconnect the battery: step 10, image 1 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Disconnect the battery: step 10, image 2 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Disconnect the battery: step 10, image 3 of 3
    • Use the pointed end of a spudger to push each side of the battery connector to loosen it.
  11. Lenovo Legion 5 17ACH6H Left SSD Replacement: step 11, image 1 of 2 Lenovo Legion 5 17ACH6H Left SSD Replacement: step 11, image 2 of 2
    • Use the flat end of a spudger to push out and disconnect battery cable.
  12. Lenovo Legion 5 17ACH6H Left SSD Replacement, Left SSD removal: step 12, image 1 of 2 Lenovo Legion 5 17ACH6H Left SSD Replacement, Left SSD removal: step 12, image 2 of 2
    • Use a Phillips screwdriver to remove the four screws securing the left SSD shield to the motherboard:
    • Three 3.3 mm PH1 screws.
    • One 5 mm PH00 screw.
    • During reassembly, make sure the two holes on the left side of the shield align with the posts on the chassis.
  13. Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the SSD shield: step 13, image 1 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the SSD shield: step 13, image 2 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the SSD shield: step 13, image 3 of 3
    • Grab the SSD shield and lift up to remove it.
  14. Lenovo Legion 5 17ACH6H Left SSD Replacement: step 14, image 1 of 2 Lenovo Legion 5 17ACH6H Left SSD Replacement: step 14, image 2 of 2
    • Use a Phillips screwdriver to remove the 2.8 mm PH1 screw securing the SSD to the motherboard.
    • The SSD will spring up to about 30˚ when the screw is removed.
  15. Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the left SSD: step 15, image 1 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the left SSD: step 15, image 2 of 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the left SSD: step 15, image 3 of 3
    • Grip the edges of the SSD near the screw indent.
    • Gently pull to remove the SSD.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion Answers community for help.
Chayton Ritter
22,518 Reputation
105 Guides authored
Guide Team Member of Guide Team
Staff
9 Members
11,420 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 87
All Time: 3,683
