Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement
  1. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement, Base Panel: step 1, image 1 of 2 Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement, Base Panel: step 1, image 2 of 2
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement: step 2, image 1 of 1
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement, Wi-Fi  Card: step 3, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
  4. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement: step 4, image 1 of 1
    • Pull the Wi-Fi card directly out of its port.
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 27
All Time: 503
