Lenovo N20p Chromebook Keyboard Replacement
  1. Lenovo N20p Chromebook Keyboard Replacement, Keyboard: step 1, image 1 of 2 Lenovo N20p Chromebook Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Power down the Chromebook before starting any repair.
    • Remove the two 3.5 mm Phillips #0 screws using a screwdriver.
    • It is only necessary to remove these two screws to complete this step.
  2. Lenovo N20p Chromebook Keyboard Replacement: step 2, image 1 of 2 Lenovo N20p Chromebook Keyboard Replacement: step 2, image 2 of 2
    • Use the hook of the metal spudger to carefully lift up the keyboard.
    • Lift the keyboard carefully. If you lift too quickly, it might break the two cables that connect the keyboard to the motherboard.
  3. Lenovo N20p Chromebook Keyboard Replacement: step 3, image 1 of 3 Lenovo N20p Chromebook Keyboard Replacement: step 3, image 2 of 3 Lenovo N20p Chromebook Keyboard Replacement: step 3, image 3 of 3
    • Carefully, disconnect the keyboard cable from the motherboard carefully by pulling on the blue tab of the cable.
    • You will now be able to replace the keyboard.
Shihao Cao
497 Reputation
4 Guides authored
UW Tacoma, Team S1-G2, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G2, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G2
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 290
