You're viewing a previously published version of this guide.  View latest version
Older Newer
Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement
Alex Cass
Alex Cass and 5 other contributors
Last updated on December 18, 2019
10 minutes
Moderate
Introduction
Go to step 1
To replace the trackpad or keyboard of the Lenovo N21 Chromebook, the whole panel including both parts will need to be replaced.
If you are trying to replace other parts within the Lenovo N21 Chromebook, the trackpad and keyboard panel will have to be removed from the bottom housing in order to access these interior parts.
Parts
Tools
Show more…
  1. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement, Keyboard and Trackpad Panel: step 1, image 1 of 2 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement, Keyboard and Trackpad Panel: step 1, image 2 of 2
    • Power down the Chromebook before starting any repair.
    • Opening up your Chromebook voids the manufacturer warranty.
    • Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
  2. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: step 2, image 1 of 2 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry off the four rubber pegs from the bottom housing.
  3. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: step 3, image 1 of 2 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: step 3, image 2 of 2
    • Use a screwdriver to remove the four 5.0mm Phillips screws located under the rubber soles.
  4. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: step 4, image 1 of 3 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: step 4, image 2 of 3 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: step 4, image 3 of 3
    • Flip the laptop over and open the screen.
    • Gently pry the keyboard and trackpad panel away from the bottom housing using a plastic opening tool.
    • Once completely separated, do not immediately pull the panel completely away from the bottom housing. There are wires that are still connecting the panel to the rest of the internals of the Chromebook.
  5. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: step 5, image 1 of 2 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: step 5, image 2 of 2
    • Disconnect the keyboard ribbon cable by lifting the ZIF connector lock with a plastic opening tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  6. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: step 6, image 1 of 3 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: step 6, image 2 of 3 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: step 6, image 3 of 3
    • Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  7. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: step 7, image 1 of 1
    • Remove the keyboard and trackpad panel away from the device.
Alex Cass
285 Reputation
2 Guides authored
Cal Poly, Team S21-G2, Livingston Spring 2017 Member of Cal Poly, Team S21-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G2
4 Members
12 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 19
All Time: 2,355
