Lenovo N23 Chromebook Battery Replacement
  1. Lenovo N23 Chromebook Battery Replacement, Battery: step 1, image 1 of 2 Lenovo N23 Chromebook Battery Replacement, Battery: step 1, image 2 of 2
    • Before starting, make sure that the laptop is powered off and completely unplugged from the charger.
    • Remove the eight 6.0 mm screws holding the back cover into place using a Phillips #0 screwdriver.
  2. Lenovo N23 Chromebook Battery Replacement: step 2, image 1 of 1
    • Flip the device over.
    • Slide a plastic opening tool between the back cover and keyboard.
    • Carefully pry upwards until you hear a click.
    • Following the seam, slide the opening tool all the way around the front cover, prying upwards occasionally until the keyboard and trackpad are loose from the back cover.
    • Lift the keyboard panel up to reveal the internals.
    • Don't lift the keyboard panel too violently, as there is still a cable attachment to the motherboard.
  3. Lenovo N23 Chromebook Battery Replacement: step 3, image 1 of 3 Lenovo N23 Chromebook Battery Replacement: step 3, image 2 of 3 Lenovo N23 Chromebook Battery Replacement: step 3, image 3 of 3
    • You can now access the internals of the computer.
    • Disconnect the two ribbon cables that connect from the motherboard to the front cover.
    • Using the iFixit opening tool, flip up the black tab holding the keyboard ribbon cable and then pull the cable out.
    • Using the opening tool, flip the white tab holding the mouse ribbon cable and then pull the cable out.
  4. Lenovo N23 Chromebook Battery Replacement: step 4, image 1 of 2 Lenovo N23 Chromebook Battery Replacement: step 4, image 2 of 2
    • Lift the keyboard panel from the case and fully remove it from the device.
  5. Lenovo N23 Chromebook Battery Replacement: step 5, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the battery in place.
  6. Lenovo N23 Chromebook Battery Replacement: step 6, image 1 of 3 Lenovo N23 Chromebook Battery Replacement: step 6, image 2 of 3 Lenovo N23 Chromebook Battery Replacement: step 6, image 3 of 3
    • Disconnect the battery cable using a plastic opening tool by pulling on the black plastic lip.
    • Lift the battery out of the laptop.
2 other people completed this guide.
One Comment
What happens, say the thing is barely alive and partially destroyed, if the battery is bent? i want save as many parts as posible
Wyatt Smith - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 994
