Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement
  1. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement, Disc Tray Locking Mechanism: step 1, image 1 of 2 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement, Disc Tray Locking Mechanism: step 1, image 2 of 2
    • Flip the unit over so that way the bottom is facing you.
    • Remove the two black 7.6mm Phillips #0 screws from the bottom cover.
  2. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: step 2, image 1 of 2 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: step 2, image 2 of 2
    • Use the iFixit Opening Tool to gently pry the unit apart to gain access to the interior.
    • If the top seems stuck, run the iFixit Opening Tool along the edge while simultaneously pulling up on the top with your fingers. Continue to apply pressure until it opens completely.
  3. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: step 3, image 1 of 2 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: step 3, image 2 of 2
    • Open the device tray by inserting a paper clip into the eject hole.
  4. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: step 4, image 1 of 2 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: step 4, image 2 of 2
    • Turn the unit over and remove the two silver 3mm Phillips #0 screws from the aluminum cover.
  5. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: step 5, image 1 of 1
    • Lift the silver coverup to expose the internal components.
    • If the cover seems stuck gently pull up on one edge. The cover should remove completely after one side is free.
  6. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: step 6, image 1 of 2 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: step 6, image 2 of 2
    • Remove the single 3mm Phillips #0 screw.
  7. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: step 7, image 1 of 2 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: step 7, image 2 of 2
    • Lift and remove the silver tray locking mechanism by detaching the spring which is hooked on the white plastic internal component.
    • Be careful when removing this mechanism—the spring is delicate.
Matthew Green
337 Reputation
2 Guides authored
IUPUI, Team S2-G1, Harley Summer 2018 Member of IUPUI, Team S2-G1, Harley Summer 2018
IUPUI-HARLEY-SU18S2G1
3 Members
2 Guides authored
2 Comments
Hey there, I tried to fix mine, but 3 tiny black springs came from nowhere, and now I dunno what should I do with them.
RuCharlz - Reply
Me too, i'm stuck
Wassim Ajili -
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 33
All Time: 1,844
