Lenovo Tab 2 A8 Battery Replacement
  1. Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: step 1, image 1 of 3 Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: step 1, image 2 of 3 Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Battery Replacement: step 2, image 1 of 3 Lenovo Tab 2 A8 Battery Replacement: step 2, image 2 of 3 Lenovo Tab 2 A8 Battery Replacement: step 2, image 3 of 3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Battery Replacement, Battery: step 3, image 1 of 2 Lenovo Tab 2 A8 Battery Replacement, Battery: step 3, image 2 of 2
    Buy
    • Using a counterclockwise motion with the Phillips #000 screwdriver, remove the M1.4 × 2.5 screw that holds down the copper strip connected to the battery.
    • With a pair of Tweezers, carefully unplug the strip connecting the battery to the motherboard.
  4. Lenovo Tab 2 A8 Battery Replacement: step 4, image 1 of 3 Lenovo Tab 2 A8 Battery Replacement: step 4, image 2 of 3 Lenovo Tab 2 A8 Battery Replacement: step 4, image 3 of 3
    • Working your way around the edge of the battery, pry out the battery using a plastic opening tool
    • Be aware that the battery is held in by double-sided tape on the underside
5 other people completed this guide.
2 Comments
Thanks... but where do we find a replacement battery?
sebtrudel - Reply
I fixit might have a replacement battery
storm builder - Reply
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 69
All Time: 11,665
