Lenovo Tab 2 A8 Speaker Replacement
  1. Lenovo Tab 2 A8 Speaker Replacement, Removing the Back Panel: step 1, image 1 of 3 Lenovo Tab 2 A8 Speaker Replacement, Removing the Back Panel: step 1, image 2 of 3 Lenovo Tab 2 A8 Speaker Replacement, Removing the Back Panel: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Speaker Replacement: step 2, image 1 of 3 Lenovo Tab 2 A8 Speaker Replacement: step 2, image 2 of 3 Lenovo Tab 2 A8 Speaker Replacement: step 2, image 3 of 3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Speaker Replacement, Speaker: step 3, image 1 of 3 Lenovo Tab 2 A8 Speaker Replacement, Speaker: step 3, image 2 of 3 Lenovo Tab 2 A8 Speaker Replacement, Speaker: step 3, image 3 of 3
    • Using a counterclockwise motion with the Phillips #000 screwdriver, unscrew the three M1.4 × 2.5 screws that hold the white plastic speaker housing in place.
    • Pry off the speaker housing utilizing a metal spudger.
  4. Lenovo Tab 2 A8 Speaker Replacement: step 4, image 1 of 1
    • Insert a plastic probe through the tab and pry to remove the speaker from its socket.
    • Be careful not to damage the wires attached to the speaker. Don't forcibly remove the speaker from its socket. The speaker is magnetic, don't use metal tools.
  5. Lenovo Tab 2 A8 Speaker Replacement: step 5, image 1 of 1
    • Using a soldering iron, desolder the contacts that connect the speaker wires to the speaker chip.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 729
