Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement
  1. Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Removing the Back Panel: step 1, image 1 of 3 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Removing the Back Panel: step 1, image 2 of 3 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Removing the Back Panel: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement: step 2, image 1 of 3 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement: step 2, image 2 of 3 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement: step 2, image 3 of 3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Volume & Power Button Sensor: step 3, image 1 of 2 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Volume & Power Button Sensor: step 3, image 2 of 2
    Buy
    • Use tweezers to gently lift the button panel away from the device. Be aware that pulling on the ribbon with too much force could tear the ribbon cable.
    • Carefully desolder the button strip contact point.
3 other people completed this guide.
Taylor Smith
382 Reputation
2 Guides authored
IUPUI, Team 2-4, Baechle Spring 2017 Member of IUPUI, Team 2-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G4
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 38
All Time: 2,774
