Lenovo ThinkCentre M92p Hard Drive Replacement
  1. Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
    • Power off your ThinkCentre M92p, and unplug the power cable from the electrical outlet.
  2. Lenovo ThinkCentre M92p Hard Drive Replacement: step 2, image 1 of 2 Lenovo ThinkCentre M92p Hard Drive Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the middle black screw located on the back of the ThinkCentre.
  3. Lenovo ThinkCentre M92p Hard Drive Replacement: step 3, image 1 of 3 Lenovo ThinkCentre M92p Hard Drive Replacement: step 3, image 2 of 3 Lenovo ThinkCentre M92p Hard Drive Replacement: step 3, image 3 of 3
    • Use your thumbs and slide the metal housing towards the front, to remove the cover.
  4. Lenovo ThinkCentre M92p Hard Drive Replacement: step 4, image 1 of 2 Lenovo ThinkCentre M92p Hard Drive Replacement: step 4, image 2 of 2
    • Unplug the black connector from the damaged hard drive.
  5. Lenovo ThinkCentre M92p Hard Drive Replacement: step 5, image 1 of 3 Lenovo ThinkCentre M92p Hard Drive Replacement: step 5, image 2 of 3 Lenovo ThinkCentre M92p Hard Drive Replacement: step 5, image 3 of 3
    • Use the Phillips #1 screwdriver to remove the two black screws holding the hard drive to the chassis.
  6. Lenovo ThinkCentre M92p Hard Drive Replacement: step 6, image 1 of 3 Lenovo ThinkCentre M92p Hard Drive Replacement: step 6, image 2 of 3 Lenovo ThinkCentre M92p Hard Drive Replacement: step 6, image 3 of 3
    • Do not try to remove the hard drive right away .There is a red/black cable connected to the motherboard, right below the hard drive. Gently disconnect it from the *green* motherboard***.
  7. Lenovo ThinkCentre M92p Hard Drive Replacement: step 7, image 1 of 3 Lenovo ThinkCentre M92p Hard Drive Replacement: step 7, image 2 of 3 Lenovo ThinkCentre M92p Hard Drive Replacement: step 7, image 3 of 3
    • Flip over the disconnected caddy/tray and use the Phillips #1 screwdriver to remove the four screws from the bottom. Then remove the hard drive.
3 other people completed this guide.
Innocent bakajika
217 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 115
All Time: 5,340
