Lenovo ThinkPad Edge E420s Hard Drive Replacement
  1. Lenovo ThinkPad Edge E420s Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Lenovo ThinkPad Edge E420s Hard Drive Replacement: step 2, image 1 of 1
    • Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
  3. Lenovo ThinkPad Edge E420s Hard Drive Replacement: step 3, image 1 of 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: step 3, image 2 of 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: step 3, image 3 of 3
    • Swing the cover out slightly like a hinge.
    • Pull the cover directly away from the case towards the base of the laptop.
    • Lift the cover up and away from the device to remove it.
    • You may hear a slight pop when you pull the cover off.
  4. Lenovo ThinkPad Edge E420s Hard Drive Replacement: step 4, image 1 of 1
    • Use the clear tab to slide the hard drive out of the device.
  5. Lenovo ThinkPad Edge E420s Hard Drive Replacement: step 5, image 1 of 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: step 5, image 2 of 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: step 5, image 3 of 3
    • To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
    • Slide the old hard drive directly out.
    • When reassembling, make sure the hard drive is securely in the case before beginning.
4 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 25
All Time: 2,905
