Lenovo ThinkPad Helix Screen Replacement
  1. Lenovo ThinkPad Helix Screen Replacement, Screen: step 1, image 1 of 1
    • Using a plastic opening tool or opening pick, gently pry the screen off.
    • If possible, use plastic tools to pry the screen, as the metal tool as shown in the image can potentially damage your device.
    • You will need to use a little bit of force to pry it open. There is little indent that goes around the tablet. You will insert your tool between this indent and pry it open.
    • Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
  2. Lenovo ThinkPad Helix Screen Replacement: step 2, image 1 of 3 Lenovo ThinkPad Helix Screen Replacement: step 2, image 2 of 3 Lenovo ThinkPad Helix Screen Replacement: step 2, image 3 of 3
    • Lift the screen up slowly.
    • Once separated, you can not fully take it off due to some cable connections.
    • Open the clips of the ZIF connectors and gently grab the cable to pull it out.
  3. Lenovo ThinkPad Helix Screen Replacement: step 3, image 1 of 1
    • Once the cables are disconnected, remove the screen.
3 other people completed this guide.
Manuel Parra Rocha
494 Reputation
2 Guides authored
Gateway, Team S1-G6, Saknee Fall 2019 Member of Gateway, Team S1-G6, Saknee Fall 2019
GCC-SAKNEE-F19S1G6
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 10
All Time: 1,881
