Lenovo ThinkPad T15 Gen 2 Battery Replacement
  1. Lenovo ThinkPad T15 Gen 2 Battery Replacement, Unfasten the lower case: step 1, image 1 of 2 Lenovo ThinkPad T15 Gen 2 Battery Replacement, Unfasten the lower case: step 1, image 2 of 2
    • Use a Phillips #1 screwdriver to loosen the eight captive screws securing the lower case.
  2. Lenovo ThinkPad T15 Gen 2 Battery Replacement, Insert an opening pick: step 2, image 1 of 2 Lenovo ThinkPad T15 Gen 2 Battery Replacement, Insert an opening pick: step 2, image 2 of 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Lenovo ThinkPad T15 Gen 2 Battery Replacement, Release the front clips: step 3, image 1 of 3 Lenovo ThinkPad T15 Gen 2 Battery Replacement, Release the front clips: step 3, image 2 of 3 Lenovo ThinkPad T15 Gen 2 Battery Replacement, Release the front clips: step 3, image 3 of 3
    • Angle the pick down at about 30˚.
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Lenovo ThinkPad T15 Gen 2 Battery Replacement, Release the USB clip: step 4, image 1 of 2 Lenovo ThinkPad T15 Gen 2 Battery Replacement, Release the USB clip: step 4, image 2 of 2
    • Insert an opening tool between the lower case and the chassis, just to the right of the USB port on the left edge.
    • Pry the opening case up to release the clip next to the USB port.
    • It may take significant force and multiple attempts to release the clip. You will hear a popping noise when the clip releases.
  5. Lenovo ThinkPad T15 Gen 2 Battery Replacement: step 5, image 1 of 2 Lenovo ThinkPad T15 Gen 2 Battery Replacement: step 5, image 2 of 2
    • Insert an opening pick on the left edge above the USB port. Slide the pick all the way up to the ethernet port to release the clips.
  6. Lenovo ThinkPad T15 Gen 2 Battery Replacement: step 6, image 1 of 2 Lenovo ThinkPad T15 Gen 2 Battery Replacement: step 6, image 2 of 2
    • Insert an opening pick on the right edge near the corner.
    • Slide the pick along the right edge all the way to the HDMI port to release the rest of the clips.
  7. Lenovo ThinkPad T15 Gen 2 Battery Replacement: step 7, image 1 of 3 Lenovo ThinkPad T15 Gen 2 Battery Replacement: step 7, image 2 of 3 Lenovo ThinkPad T15 Gen 2 Battery Replacement: step 7, image 3 of 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  8. Lenovo ThinkPad T15 Gen 2 Battery Replacement, Disconnect the battery: step 8, image 1 of 3 Lenovo ThinkPad T15 Gen 2 Battery Replacement, Disconnect the battery: step 8, image 2 of 3 Lenovo ThinkPad T15 Gen 2 Battery Replacement, Disconnect the battery: step 8, image 3 of 3
    • Grip the pull tab on the battery connector with your fingers and gently pull away from the socket to disconnect it.
  9. Lenovo ThinkPad T15 Gen 2 Battery Replacement, Unfasten the battery: step 9, image 1 of 2 Lenovo ThinkPad T15 Gen 2 Battery Replacement, Unfasten the battery: step 9, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the three 5.4 mm-long screws securing the battery.
  10. Lenovo ThinkPad T15 Gen 2 Battery Replacement, Remove the battery: step 10, image 1 of 3 Lenovo ThinkPad T15 Gen 2 Battery Replacement, Remove the battery: step 10, image 2 of 3 Lenovo ThinkPad T15 Gen 2 Battery Replacement, Remove the battery: step 10, image 3 of 3
    • Push the battery toward the top of the laptop to release its plastic clips.
    • Lift the battery straight out of its recess and remove it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
127,654 Reputation
592 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 138
All Time: 3,170
