Lenovo ThinkPad T400s CMOS Battery Replacement
Morgan Montalvo
Morgan Montalvo and 3 other contributors
Last updated on August 31, 2015
20 minutes
Easy
Introduction
Go to step 1
This guide will show you how to replace your CMOS battery.
Tools
Show more…
  1. Lenovo ThinkPad T400s CMOS Battery Replacement, Keyboard: step 1, image 1 of 2 Lenovo ThinkPad T400s CMOS Battery Replacement, Keyboard: step 1, image 2 of 2
    • Remove the Phillips #0-6mm screw.
    • Lift up the back cover to the RAM cards.
  2. Lenovo ThinkPad T400s CMOS Battery Replacement: step 2, image 1 of 2 Lenovo ThinkPad T400s CMOS Battery Replacement: step 2, image 2 of 2
    • Pull the lock for the baterry to the left to unlock.
    • While holding the tab in the unlocked position, remove the battery.
  3. Lenovo ThinkPad T400s CMOS Battery Replacement: step 3, image 1 of 1
    • Remove the three Phillips #0-6mm screws on the back panel.
    • These screws are marked with a keyboard symbol next to them.
  4. Lenovo ThinkPad T400s CMOS Battery Replacement: step 4, image 1 of 3 Lenovo ThinkPad T400s CMOS Battery Replacement: step 4, image 2 of 3 Lenovo ThinkPad T400s CMOS Battery Replacement: step 4, image 3 of 3
    • Turn the computer over and open the lid.
    • Wedge the small metal spudger between the palm rest and the keyboard.
  5. Lenovo ThinkPad T400s CMOS Battery Replacement: step 5, image 1 of 3 Lenovo ThinkPad T400s CMOS Battery Replacement: step 5, image 2 of 3 Lenovo ThinkPad T400s CMOS Battery Replacement: step 5, image 3 of 3
    • Lift up the keyboard, but be careful not to completely remove.
    • Don't lift the keyboard too quickly, there is a connector cable you must disconnect first.
    • Wedge the small plastic opening tool underneath copper band and tilt back.
    • Remove keyboard to replace.
  6. Lenovo ThinkPad T400s CMOS Battery Replacement, CMOS Battery: step 6, image 1 of 1
    • Gently pull the back-up battery from underneath the front panel.
  7. Lenovo ThinkPad T400s CMOS Battery Replacement: step 7, image 1 of 2 Lenovo ThinkPad T400s CMOS Battery Replacement: step 7, image 2 of 2
    • Pull on the black connection piece and remove the back-up battery.
4 other people completed this guide.
Morgan Montalvo
652 Reputation
3 Guides authored
Cal Poly, Team 6-18, Maness Spring 2015 Member of Cal Poly, Team 6-18, Maness Spring 2015
CPSU-MANESS-S15S6G18
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 69
All Time: 21,572
