Lenovo ThinkPad T440p Display Replacement
  1. Lenovo ThinkPad T440p Display Replacement, Display: step 1, image 1 of 2 Lenovo ThinkPad T440p Display Replacement, Display: step 1, image 2 of 2
    • Flip the laptop over so that the bottom of the laptop is facing you.
  2. Lenovo ThinkPad T440p Display Replacement: step 2, image 1 of 2 Lenovo ThinkPad T440p Display Replacement: step 2, image 2 of 2
    • Slide each of the battery latches away from each other into the unlocked location.
  3. Lenovo ThinkPad T440p Display Replacement: step 3, image 1 of 2 Lenovo ThinkPad T440p Display Replacement: step 3, image 2 of 2
    • Slide the battery out of the battery compartment.
  4. Lenovo ThinkPad T440p Display Replacement: step 4, image 1 of 2 Lenovo ThinkPad T440p Display Replacement: step 4, image 2 of 2
    • Flip the laptop over so that the top of the laptop faces you.
  5. Lenovo ThinkPad T440p Display Replacement: step 5, image 1 of 2 Lenovo ThinkPad T440p Display Replacement: step 5, image 2 of 2
    • Lift the lid of the laptop until the top of the lid is touching the ground.
  6. Lenovo ThinkPad T440p Display Replacement: step 6, image 1 of 3 Lenovo ThinkPad T440p Display Replacement: step 6, image 2 of 3 Lenovo ThinkPad T440p Display Replacement: step 6, image 3 of 3
    • Carefully pry the display bezels away from the display using the plastic opening tool.
    • The edges on the underside of the bezel that touches the display may be sharp.
  7. Lenovo ThinkPad T440p Display Replacement: step 7, image 1 of 2 Lenovo ThinkPad T440p Display Replacement: step 7, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the four 3mm display screws.
  8. Lenovo ThinkPad T440p Display Replacement: step 8, image 1 of 1
    • Carefully lift the display up and place it on the keyboard.
    • Don't remove it from the laptop. There's a cable still attached to it.
  9. Lenovo ThinkPad T440p Display Replacement: step 9, image 1 of 3 Lenovo ThinkPad T440p Display Replacement: step 9, image 2 of 3 Lenovo ThinkPad T440p Display Replacement: step 9, image 3 of 3
    • Locate the latch attached to the display cable.
    • Grab the latch and flip it over so that it is facing away from you.
  10. Lenovo ThinkPad T440p Display Replacement: step 10, image 1 of 1
    • Gently remove the cable from the display by pulling it directly away from you.
  11. Lenovo ThinkPad T440p Display Replacement: step 11, image 1 of 2 Lenovo ThinkPad T440p Display Replacement: step 11, image 2 of 2
    • Remove the display from the computer.
5 other people completed this guide.
Rasheed Adam
337 Reputation
1 Guide authored
2 Comments
Easy peasy! Got a fresh 1080p IPS display into my ThinkPad thanks to this guide!
Noah - Reply
What display did you have before? I have heard that there are two different display cables and if you didn't already have a 900p screen/already had a 768p screen, then you will need a new display cable to do the FHD display swap.
Annika Genisis -
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 78
All Time: 3,154
