Lenovo ThinkPad T440p Fan Replacement
  1. Lenovo ThinkPad T440p Fan Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop so that the back is facing up.
  2. Lenovo ThinkPad T440p Fan Replacement: step 2, image 1 of 2 Lenovo ThinkPad T440p Fan Replacement: step 2, image 2 of 2
    • Slide the battery latches to the unlocked position.
  3. Lenovo ThinkPad T440p Fan Replacement: step 3, image 1 of 2 Lenovo ThinkPad T440p Fan Replacement: step 3, image 2 of 2
    • Slide the battery pack out of the battery slot.
  4. Lenovo ThinkPad T440p Fan Replacement, Back Cover: step 4, image 1 of 2 Lenovo ThinkPad T440p Fan Replacement, Back Cover: step 4, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
  5. Lenovo ThinkPad T440p Fan Replacement: step 5, image 1 of 1
    • Slide down the back cover.
  6. Lenovo ThinkPad T440p Fan Replacement: step 6, image 1 of 1
    • Remove the back cover.
  7. Lenovo ThinkPad T440p Fan Replacement, Fan: step 7, image 1 of 2 Lenovo ThinkPad T440p Fan Replacement, Fan: step 7, image 2 of 2
    • Using the spudger detach the cable that is connected to the computer.
  8. Lenovo ThinkPad T440p Fan Replacement: step 8, image 1 of 2 Lenovo ThinkPad T440p Fan Replacement: step 8, image 2 of 2
    • Remove the tape that is over the cable.
  9. Lenovo ThinkPad T440p Fan Replacement: step 9, image 1 of 3 Lenovo ThinkPad T440p Fan Replacement: step 9, image 2 of 3 Lenovo ThinkPad T440p Fan Replacement: step 9, image 3 of 3
    • Screws are attached to the heat sink. Do not try to remove them; just have the screws loosened.
    • Unscrew the four screws that are attached to the heat sink by using a Phillips #0 screwdriver.
  10. Lenovo ThinkPad T440p Fan Replacement: step 10, image 1 of 3 Lenovo ThinkPad T440p Fan Replacement: step 10, image 2 of 3 Lenovo ThinkPad T440p Fan Replacement: step 10, image 3 of 3
    • Remove the fan.
Christian Abad
1,431 Reputation
7 Guides authored
One Comment
The guide could go one step further as this model features a replaceable CPU.
cubytus - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 64
All Time: 3,708
