Introduction
The RAM is a simple replacement that only requires your fingers to remove it. Make sure to only apply pressure on the edges and not the RAM itself so as not to damage any parts it might be connected to.
Use a Phillips #1 screwdriver to remove the two 8mm screws holding the back cover.
In the first memory slot, use your fingertips to spread the two white tabs that are holding down the RAM. The RAM will raise to an angle.
3 other people completed this guide.
