Lenovo ThinkPad T470 Bottom Cover Replacement
  1. Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: step 1, image 1 of 3 Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: step 1, image 2 of 3 Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: step 1, image 3 of 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 Bottom Cover Replacement: step 2, image 1 of 3 Lenovo ThinkPad T470 Bottom Cover Replacement: step 2, image 2 of 3 Lenovo ThinkPad T470 Bottom Cover Replacement: step 2, image 3 of 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Bottom Cover Replacement, Bottom Cover: step 3, image 1 of 2 Lenovo ThinkPad T470 Bottom Cover Replacement, Bottom Cover: step 3, image 2 of 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 Bottom Cover Replacement: step 4, image 1 of 3 Lenovo ThinkPad T470 Bottom Cover Replacement: step 4, image 2 of 3 Lenovo ThinkPad T470 Bottom Cover Replacement: step 4, image 3 of 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 Bottom Cover Replacement: step 5, image 1 of 1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
2 other people completed this guide.
Kristen Gismondi
92,167 Reputation
241 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,468 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 33
Past 30 Days: 86
All Time: 3,707
