Lenovo ThinkPad T480 Back Cover Replacement
  1. Lenovo ThinkPad T480 Back Cover Replacement, External Battery: step 1, image 1 of 2 Lenovo ThinkPad T480 Back Cover Replacement, External Battery: step 1, image 2 of 2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Back Cover Replacement: step 2, image 1 of 3 Lenovo ThinkPad T480 Back Cover Replacement: step 2, image 2 of 3 Lenovo ThinkPad T480 Back Cover Replacement: step 2, image 3 of 3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Back Cover Replacement, Back Cover: step 3, image 1 of 2 Lenovo ThinkPad T480 Back Cover Replacement, Back Cover: step 3, image 2 of 2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Back Cover Replacement: step 4, image 1 of 3 Lenovo ThinkPad T480 Back Cover Replacement: step 4, image 2 of 3 Lenovo ThinkPad T480 Back Cover Replacement: step 4, image 3 of 3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
3 other people completed this guide.
Sarah Westberg
24,106 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
2 Comments
Dont forget the 3 clips in the removable battery area. No one mentioned those and I ended up breaking a clip and cracking the bottom cover of my T480... :(
Neccros - Reply
Hey @neccros! Thanks for the feedback. I'm very sorry you cracked your bottom cover. I've updated the guide to incorporate your experience.
Sarah Westberg -
Past 24 Hours: 9
Past 7 Days: 67
Past 30 Days: 273
All Time: 6,877
