Introduction
The internal battery of a laptop supplies power to the device when it is not plugged into an outlet. When the battery begins to lose power, has started to drain quickly or is damaged (like in the case of a swollen battery), you will want to replace the battery of your Lenovo ThinkPad T480.
This guide will walk you through the steps to replacing the internal laptop battery of your Lenovo ThinkPad T480.
Prior to beginning this guide, be sure to disable the internal battery first, then turn off the device and remove it from the charging cable.
Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
8 other people completed this guide.
4 Comments
"What you need" contains a wrong part.
Hi @cumledomla, I've added the internal battery for this guide. Thanks for pointing that out! The external battery will show up in the "What you need" section because it's imported from the prerequisite guide for the external battery. Hope this helps.
Battery 2 is the external battery.
