Lenovo ThinkPad T480 LCD Screen Replacement
  1. Lenovo ThinkPad T480 LCD Screen Replacement, External Battery: step 1, image 1 of 2 Lenovo ThinkPad T480 LCD Screen Replacement, External Battery: step 1, image 2 of 2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 LCD Screen Replacement: step 2, image 1 of 3 Lenovo ThinkPad T480 LCD Screen Replacement: step 2, image 2 of 3 Lenovo ThinkPad T480 LCD Screen Replacement: step 2, image 3 of 3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 LCD Screen Replacement, Back Cover: step 3, image 1 of 2 Lenovo ThinkPad T480 LCD Screen Replacement, Back Cover: step 3, image 2 of 2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 LCD Screen Replacement: step 4, image 1 of 3 Lenovo ThinkPad T480 LCD Screen Replacement: step 4, image 2 of 3 Lenovo ThinkPad T480 LCD Screen Replacement: step 4, image 3 of 3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 LCD Screen Replacement, Internal Battery: step 5, image 1 of 2 Lenovo ThinkPad T480 LCD Screen Replacement, Internal Battery: step 5, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
  6. Lenovo ThinkPad T480 LCD Screen Replacement: step 6, image 1 of 3 Lenovo ThinkPad T480 LCD Screen Replacement: step 6, image 2 of 3 Lenovo ThinkPad T480 LCD Screen Replacement: step 6, image 3 of 3
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 LCD Screen Replacement: step 7, image 1 of 3 Lenovo ThinkPad T480 LCD Screen Replacement: step 7, image 2 of 3 Lenovo ThinkPad T480 LCD Screen Replacement: step 7, image 3 of 3
    • Using the black nylon spudger, wedge the battery up from the case and lift it out.
  8. Lenovo ThinkPad T480 LCD Screen Replacement, LCD Assembly: step 8, image 1 of 2 Lenovo ThinkPad T480 LCD Screen Replacement, LCD Assembly: step 8, image 2 of 2
    • Remove the cables from the cable guides.
  9. Lenovo ThinkPad T480 LCD Screen Replacement: step 9, image 1 of 3 Lenovo ThinkPad T480 LCD Screen Replacement: step 9, image 2 of 3 Lenovo ThinkPad T480 LCD Screen Replacement: step 9, image 3 of 3
    • Using the Phillips #1 screwdriver, remove two 4.3 mm screws from each hinge (four total).
  10. Lenovo ThinkPad T480 LCD Screen Replacement: step 10, image 1 of 3 Lenovo ThinkPad T480 LCD Screen Replacement: step 10, image 2 of 3 Lenovo ThinkPad T480 LCD Screen Replacement: step 10, image 3 of 3
    • Lift the keyboard bezel up and slide it out from the hinges to separate it from the LCD assembly.
    • In this image, all of the internal components were removed prior to this step so your device will look somewhat different.
  11. Lenovo ThinkPad T480 LCD Screen Replacement, LCD Bezel: step 11, image 1 of 2 Lenovo ThinkPad T480 LCD Screen Replacement, LCD Bezel: step 11, image 2 of 2
    • Use the metal spudger to create a space between the bezel and lid and carefully undo the clips around the perimeter of the bezel.
  12. Lenovo ThinkPad T480 LCD Screen Replacement: step 12, image 1 of 2 Lenovo ThinkPad T480 LCD Screen Replacement: step 12, image 2 of 2
    • Finish removing the bezel from the screen using the metal spudger and your hands.
    • The bottom edge of the bezel is not connected with clips but with adhesive. Take care as you remove it so you don't bend or break the bezel.
  13. Lenovo ThinkPad T480 LCD Screen Replacement, LCD Screen: step 13, image 1 of 3 Lenovo ThinkPad T480 LCD Screen Replacement, LCD Screen: step 13, image 2 of 3 Lenovo ThinkPad T480 LCD Screen Replacement, LCD Screen: step 13, image 3 of 3
    • Remove the four 3.0 mm Phillips #1 screws from the four corners of the LCD screen.
    • Lift it up using the spudger and flip it over gently towards you.
    • The LCD screen is still connected by a connector cable so be sure not to yank or pull on the screen.
  14. Lenovo ThinkPad T480 LCD Screen Replacement: step 14, image 1 of 2 Lenovo ThinkPad T480 LCD Screen Replacement: step 14, image 2 of 2
    • Using the black nylon spudger, disconnect the display connector cable and remove the LCD screen.
3 other people completed this guide.
Sarah Westberg
24,106 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
10 Comments
For the screen replacement you really only need like 11 steps.
Step 1,2,9,10,12,35-40. All other steps are optional and it only took me 15 mins.
Batnert - Reply
Hello i was wondering how much did the screen cost you to buy?
wau bruh -
If the internal battery is disabled why do you need to remove it?
Dan Matiesanu - Reply
Hi Dan, if you disconnect the internal battery from the motherboard, (Step 12), you should be fine. We just want to make sure that there is no power to the system and the step to remove the battery is included as a precaution. Thanks!
Sarah Westberg -
@sarahw thank you but my question was more about why do you need to physically disconnect the battery if it is already disabled in BIOS?
Past 24 Hours: 26
Past 7 Days: 104
Past 30 Days: 407
All Time: 16,533
