Lenovo ThinkPad T480 Speakers Replacement
  1. Lenovo ThinkPad T480 Speakers Replacement, External Battery: step 1, image 1 of 2 Lenovo ThinkPad T480 Speakers Replacement, External Battery: step 1, image 2 of 2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Speakers Replacement: step 2, image 1 of 3 Lenovo ThinkPad T480 Speakers Replacement: step 2, image 2 of 3 Lenovo ThinkPad T480 Speakers Replacement: step 2, image 3 of 3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Speakers Replacement, Back Cover: step 3, image 1 of 2 Lenovo ThinkPad T480 Speakers Replacement, Back Cover: step 3, image 2 of 2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Speakers Replacement: step 4, image 1 of 3 Lenovo ThinkPad T480 Speakers Replacement: step 4, image 2 of 3 Lenovo ThinkPad T480 Speakers Replacement: step 4, image 3 of 3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 Speakers Replacement, Internal Battery: step 5, image 1 of 2 Lenovo ThinkPad T480 Speakers Replacement, Internal Battery: step 5, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
  6. Lenovo ThinkPad T480 Speakers Replacement: step 6, image 1 of 3 Lenovo ThinkPad T480 Speakers Replacement: step 6, image 2 of 3 Lenovo ThinkPad T480 Speakers Replacement: step 6, image 3 of 3
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 Speakers Replacement: step 7, image 1 of 3 Lenovo ThinkPad T480 Speakers Replacement: step 7, image 2 of 3 Lenovo ThinkPad T480 Speakers Replacement: step 7, image 3 of 3
    • Using the black nylon spudger, wedge the battery up from the case and lift it out.
  8. Lenovo ThinkPad T480 Speakers Replacement, Speakers: step 8, image 1 of 2 Lenovo ThinkPad T480 Speakers Replacement, Speakers: step 8, image 2 of 2
    • Using the Phillips #1 screwdriver, remove two 4.8 mm screws from the right speaker.
  9. Lenovo ThinkPad T480 Speakers Replacement: step 9, image 1 of 2 Lenovo ThinkPad T480 Speakers Replacement: step 9, image 2 of 2
    • Lift the right speaker out of the case.
    • Gently remove the speaker cable from the perimeter of the chassis, connecting the right speaker to the left speaker.
  10. Lenovo ThinkPad T480 Speakers Replacement: step 10, image 1 of 2 Lenovo ThinkPad T480 Speakers Replacement: step 10, image 2 of 2
    • Remove two 4.8 mm screws from the left speaker using the Phillips #1 screwdriver.
  11. Lenovo ThinkPad T480 Speakers Replacement: step 11, image 1 of 3 Lenovo ThinkPad T480 Speakers Replacement: step 11, image 2 of 3 Lenovo ThinkPad T480 Speakers Replacement: step 11, image 3 of 3
    • Using the black nylon spudger, remove the slide connector which attaches the left speaker to the motherboard.
    • Remove the left speaker from the case.
Sarah Westberg
24,106 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 86
All Time: 2,695
