Introduction
Use this guide to replace the camera/LED cable in your Lenovo ThinkPad T480s laptop.
Some signs your camera/LED cable may be faulty include the camera light not turning on, the camera not working, or the LED flashing. These symptoms may also indicate that the camera card is faulty, rather than the cable itself.
Before attempting a camera/LED cable , you may be able to resolve the issue using Lenovo’s troubleshooting guide.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Use the spudger to disconnect the coaxial cables from the Wi-Fi card and WWAN card.
Using the spudger, pry the LCD bezel up from the edges starting near the hinges.
Remove four 2.9 mm screws from the LCD panel using the Phillips #1 screwdriver.
Use the Phillips #1 screwdriver to remove two 2.8 mm screws from the hinge in the upper right corner.
Use the spudger to disconnect the cable from the camera card, then peel the cable up from the LCD unit.
