Introduction
Use this guide to replace the power button board in your Lenovo ThinkPad T480s laptop.
The power button board contains the button that turns on the computer when pressed. Diagnosing a faulty power button may be tricky since some of the symptoms are similar to a faulty battery or AC adapter. If you are pressing the power button but your laptop is not turning on, take a look at this Lenovo ThinkPad troubleshooting manual before attempting a power button board replacement.
If you need to perform a replacement, make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
Pull the plastic film back.
Push the clips outward to release the RAM stick.
The RAM stick will pop out at an angle. Pull the RAM stick out at the same angle.
Flip the cardboard cover off of the WWAN card.
Using the spudger, release the coaxial antenna wires from the WWAN card.
Insert the SIM eject bit or a paper clip in the hole of the SIM tray to eject it.
Remove the SIM tray.
Use the Phillips #1 screwdriver to remove a 3 mm screw from the board.
