Lenovo ThinkPad T480s Speaker Replacement
  1. Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: step 1, image 2 of 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Speaker Replacement: step 2, image 1 of 3 Lenovo ThinkPad T480s Speaker Replacement: step 2, image 2 of 3 Lenovo ThinkPad T480s Speaker Replacement: step 2, image 3 of 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Speaker Replacement: step 3, image 1 of 2 Lenovo ThinkPad T480s Speaker Replacement: step 3, image 2 of 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Speaker Replacement, Battery: step 4, image 1 of 2 Lenovo ThinkPad T480s Speaker Replacement, Battery: step 4, image 2 of 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Speaker Replacement: step 5, image 1 of 3 Lenovo ThinkPad T480s Speaker Replacement: step 5, image 2 of 3 Lenovo ThinkPad T480s Speaker Replacement: step 5, image 3 of 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Speaker Replacement, Speaker: step 6, image 1 of 3 Lenovo ThinkPad T480s Speaker Replacement, Speaker: step 6, image 2 of 3 Lenovo ThinkPad T480s Speaker Replacement, Speaker: step 6, image 3 of 3
    • Disconnect the speaker cable from the motherboard using a connector puller or spudger.
  7. Lenovo ThinkPad T480s Speaker Replacement: step 7, image 1 of 2 Lenovo ThinkPad T480s Speaker Replacement: step 7, image 2 of 2
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the right side.
  8. Lenovo ThinkPad T480s Speaker Replacement: step 8, image 1 of 3 Lenovo ThinkPad T480s Speaker Replacement: step 8, image 2 of 3 Lenovo ThinkPad T480s Speaker Replacement: step 8, image 3 of 3
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the left side.
  9. Lenovo ThinkPad T480s Speaker Replacement: step 9, image 1 of 3 Lenovo ThinkPad T480s Speaker Replacement: step 9, image 2 of 3 Lenovo ThinkPad T480s Speaker Replacement: step 9, image 3 of 3
    • Use the spudger to disconnect the hall sensor connector.
  10. Lenovo ThinkPad T480s Speaker Replacement: step 10, image 1 of 3 Lenovo ThinkPad T480s Speaker Replacement: step 10, image 2 of 3 Lenovo ThinkPad T480s Speaker Replacement: step 10, image 3 of 3
    • Lift the speakers up.
    • Disconnect the cable speakers from the routing.
    • Remove the speakers from the system.
Sarah Westberg
24,109 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 58
All Time: 1,444
