Lenovo ThinkPad T490s - Thermal Paste Replacement
Simeon Brankov
Simeon Brankov and 4 other contributors
Last updated on September 25, 2024
20 - 30 minutes
Moderate
Community-Contributed Guide
Better Introduction
Introduction
Go to step 1
This guide will show you how to open the laptop to replace the Thermal Paste. This guide will also help you upgrade the RAM or the SSD inside.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Show more…
iFixit earns commission when you buy through these links.
  1. Lenovo ThinkPad T490s - Thermal Paste Replacement, Opening the back panel: step 1, image 1 of 3 Lenovo ThinkPad T490s - Thermal Paste Replacement, Opening the back panel: step 1, image 2 of 3 Lenovo ThinkPad T490s - Thermal Paste Replacement, Opening the back panel: step 1, image 3 of 3
    • Unscrew all screws holding the back panel in place.
    • Use a prying tool to release all the clips and remove the panel.
  2. Lenovo ThinkPad T490s - Thermal Paste Replacement, Changing the thermal paste: step 2, image 1 of 3 Lenovo ThinkPad T490s - Thermal Paste Replacement, Changing the thermal paste: step 2, image 2 of 3 Lenovo ThinkPad T490s - Thermal Paste Replacement, Changing the thermal paste: step 2, image 3 of 3
    • Disconnecting the battery is highly recommended.
    • Unscrew the 4 screws holding the CPU heatsink and disconnect the fan.
    • Clean the old thermal paste from both the cooler and the CPU.
    • Use isopropyl alcohol and cotton swabs or paper towel, but be careful not to press too hard on the CPU.
    • It's also recommended to use compressed air to remove any dust in the laptop and the fan.
    • Use only enough thermal paste to cover a portion of the pad. Use a spreader if you have one.
    • The thermal paste will apply evenly after you tighten the heatsink.
    • Place the heatsink back into the unit carefully and tighten the screws in an "X" pattern to ensure even pressure. Don't forget to plug in the fan cable.
  3. Lenovo ThinkPad T490s - Thermal Paste Replacement, Other upgrades: step 3, image 1 of 1
    • Once you have the back cover opened, it is a good opportunity to upgrade the SSD. To do so, follow the SSD Replacement Guide.
2 other people completed this guide.
Simeon Brankov
7,279 Reputation
54 Guides authored
1 Guide Comment
Are you sure thermal paste should be applied to the smaller PCH die?
Bryan C - Reply
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 179
All Time: 5,726
